I did grease channels, its still the same.That window is actually going up properly I believe. It is a common problem though that the window doesn't move easily in the channel and leaves a gap because it doesn't close all the way.
You can grease the channel (lithium or other product) and the window will go up all the way and seal against the front window. Try that first before doing anything else.
