Whats the thickest tire size i can go on 18x10
Currently have 285/35/18
335/35/18Whats the thickest tire size i can go on 18x10 Currently have 285/35/18
17 inch wheel correct315 nittos on 18s
My car sits pretty low in the back and my quarter panels are rolled. I have 18x10 with 22mm offset with 305/35 drag radials. I can't fit any wider tire unless I raise the rear up.
Thank you Yes it's lowered on coil overs. I have saleen 18x9 on the front with 265-35-18 nittoMzilla, your car looks great with the wheel wells filled. Is your car lowered? What wheel/tire do you have on the front? Do you have any tire rubbing?
I have the same tires and size on the front of mine as well and mine's dropped. Not even close to rubbing at full lock.Thank you Yes it's lowered on coil overs. I have saleen 18x9 on the front with 265-35-18 nitto
555 no rubbing at all
What tire was it on the front? Cause I have a 275/35-18 in the front and honestly it looks like it needs more tire.I had 275/35/18 up front on my 95 and I had no rubbing issues there either. Lipped out like a sonofa***** though. Could have ran that tire on the 18x10 I had out back.
BFG 275/35/18 up front, 295/35/18 out back. Comp TAs IIRC.What tire was it on the front? Cause I have a 275/35-18 in the front and honestly it looks like it needs more tire.
What wheels are these?My car sits pretty low in the back and my quarter panels are rolled. I have 18x10 with 22mm offset with 305/35 drag radials. I can't fit any wider tire unless I raise the rear up.
