1 - 4 of 4 Posts
Discussion Starter · #1 ·
I own a 1965 Mustang with a 289, V8. I need to know the correct number of teeth on the flywheel I need. I currently have a 157 tooth, ad for some reason, when the engine is turned over, there is a loud ticking sound, in or out of gear. (The car des NOT RUN, it isn't even hooked up to a battery, nor will it be, due to the current problem.) So, what is the correct diameter flywheel, and # of teeth.
1965 Mustang.
289 V8
4 speed MANUAL transmission.
is the flywheel 167 tooth, 10" diameter, or 157 tooth, 10 1/2"?
What Angel is talking about is the ring gear that goes on the outside of the flywheel for a manual transmission.
The original flywheel should be the 157 tooth.
The 164 tooth is for the 302 starting in 1968.
i know i am just a girl but i know a good amount about cars the flywheel you need is a 157 tooth flywheet the outer diameter needs to be 13.294" and the inner diameter needs to be 12.025" with a pitch of 12/14 and a width of .365" there is actually one for sale on http://www.rockauto.com/catalog/raframecatalog.php
it costs around like $17 ok... have fun with your car!!!!
Love you! Brit and Angel!
1 - 4 of 4 Posts
