1 - 4 of 4 Posts
Discussion Starter · #1 ·
Trying to put together the doors on the Mach 1, but i have a problem. The glass has a bracket on the bottom that is glued on (unlike other years which are bolted on), but i dont want to spend the $175 per window the glass company said they would do it for. Anyone know what i could get that would work in gluing the bracket to the glass? It is a hard, epoxy looking glue. Thanks for your help.
You can get a 2 part epoxy at most hardware stores or department stores. It's basically the same stuff that I use to put shafts into golf clubs. you mix it and it hardens, The stronger stuff usually takes a full day to cure.
1 - 4 of 4 Posts
