1 - 4 of 4 Posts
Discussion Starter · #1 ·
Could it just be the seal that is broken? The box leaks out the liquid very fast once i fill it. How easy of a job is it to replace the seal? Ive basically rebuilt most of the motor myself but dont want to undertake something over my head. Any suggestions?
more than likely it is from the seal,common on ford products of that era,generally the worm shaft is worn out,causing play,allowing wobble and the result is a leak,1973 fixing it up? try to locate a remanufacterd unit,it may cost a little but you will be happier in the end also it takes a pitman arm puller to remove the pitman arm,sometimes a chore.
1 - 4 of 4 Posts
