1 - 5 of 5 Posts
Discussion Starter · #1 ·
I have a 1983 Mustang 5.0 HO that had a carb leak a month ago that was repaired. Even since the repair, it has a gas smell that is detectable after driving the car. I cannot smell gas while driving, but after the car sits in the garage overnight, the next morning it reeks of gas. 3 different mechanics since have looked at it, tracing the fuel line from carb to tank, they found nothing. No sign of leaks. Carb looks good. Someone said to replace the gas cap, which I did. The smell remains. It is not noticeable while driving. (Also, the car requires 5 or more pumps of the accelerator and 3 to 5 turn overs to get it to crank when cold. Once warmed up, it cranks easily the first time.) I have no idea what it could be.
Do you still have the emissions stuff on the car like the charcoal canister?
Discussion Starter · #3 ·
Thanks!
I believe that may be it! I located it and the smell is strongest right above it. I have one ordered at the local parts store and it will be here tomorrow. I'll replace it as soon as I can and let you know if that did it for sure!!
Also check the hoses as well.
Good luck
Discussion Starter · #5 ·
Replaced the charcoal filter
Still has the gas smell. Although it doesn't seem as strong. If nothing else, I now have another new part on the car. I'll check the hoses next. It only smells after a night in the garage. If it sits outside, I never small gas. Can't be too bad I wouldn't think.
Thanks for your help!
1 - 5 of 5 Posts
