1 - 3 of 3 Posts
Discussion Starter · #1 ·
My 1990 Mustang GT is leaking in the middle, towards the back of the front wheels. I'm not sure what it is, but it stains concrete easily. The car will also start and run, but once I turn it off it won't start again for several hours. Any ideas on what it could be?
Could be a fuel leak if smells like gas. Get fixed ASAP. Other than that if green, coolant, reddish, trans or steering gear, light brown, engine oil. You need to take to shop and put up in air to check. Not starting could be gas leak or bad ignition module. check fuel leak first can cause fire or explosion.
1 - 3 of 3 Posts
