1 - 2 of 2 Posts
Discussion Starter #1
I keep getting these errors when we use the oem sensor.
P0171, P0174, and P0340
The first two says that the engine is running too lean, the second one says there's a problem with the camshaft sensor. We thought we fixed the camshaft when we replaced the sensor but the error still came up, we also replaced the synchronizer. My stang is running on five of it's six cylinders, (misfiring) and this is an issue. It's also been losing power when doing simple things like turning on, and reverse parking. I'm not sure what else to do at this point, any suggestions on what can be the issue?
We checked the spark plugs and wires, and the compression, all of these are good.
1 - 2 of 2 Posts
