1 - 15 of 15 Posts
· Registered
Discussion Starter · #1 ·
I wanna go big, real big. I was wonderign if 20's would fit with no scraping or mods. I'd also like to know what tire size is recomended with a mid profile tire, i'd also like the tire to be a little wider than the rim to try and prevent possible curb rash. I know the wheel size will slow me down soem but, its not like I can go fast anyway so I dont care. Thanks for any and all input...unless ur flaming me :eek:
· Registered
I've only ever seen one set of 20s on a stang that I liked and he had a saleen body kit that made it look good, otherwise it almost always looks tacky. I'd say 18s are as big as you want to go generally
· Premium Member
i dont think 20's would fit you would have to encounter scraping on turns im guessing, ive seen them on a 99+ and that car had a bit of scraping.
· Registered
what wheels are you looking at?
a "mid-profile" tire? if that was the case your wheels would have the diameter of a monster truck.
your tires will look like very expensive black rubber bands pulled around the wheels. i don't know da phat shiat like that, but i'm sure a 20x8 wheel will be just fine. rubbing only happens when the wheel is too wide (problems start at 9") or if the car is slammed down to the ground.
austin
· Premium Member
2013 GT Track-Pack
ive seen a couple sets of 20s that look good... one thing is your gonna look like youre really high off the ground even if your car is dropped... so thats somethin to think about.
· Registered
you may have to roll your fenders a bit.
1 - 15 of 15 Posts
