1 - 7 of 7 Posts
Discussion Starter #1
-Procharger 8+ psi w/ D-1SC Supercharger
-K&N Fuel Injection Performance Kit +14.7 HP
-Hotchkis Sway Bar Kit 1” solid rear, 1 7/16” hollow front
-Holley Throttle Body Assembly 90 mm
-American Racing Vintage Torq-Thrust M Anthracite w/ Mach Lip Rims (21.6 lbs)
-Pace Setter Long-Tube Headers 1 ¾” tubes 3” collector
-Magnaflow Cat-Back Exhaust System 3” tubing 3.5” tips
I'd also like to paint the body windveil blue clearcoat metallic (ford mustang color) and paint the roof black.
what do you think?
Don't forget 40-55# injectors, the proper PCM tuning and a new clutch or a well built automatic(depending on the trans your car has).
You're going to want to do more suspension work too, the sway bar kit isn't enough.
Don't forget a good set of tires too, cheapy street tires will be worthless.
I have a P1-SC on my '89 GTA and it's a blast to drive, good luck!!!
i think it would be pushin over 500hp ! but if u paint it a ford color then your car will have very strange problems always going on . ever here of karma ? paint it black with a silver stripe down the bottm . ''intimidater'' !!!
stock ls1 = 330 hp .
+ supercharger = about 450 hp .
fuel inject kit = 465 hp
long tube header +catback = 500+ !!!!!
DUDE THAT CAR IS ALREADY BADASS!!!! I like honestly all of those parts and all friends use those parts and love them! So good luck. Sweet car! :)
if you did all that man, that would be one..bad...camaro!!! do it man and have fun! good luck with this road terrorizer!
1 - 7 of 7 Posts
