1 - 3 of 3 Posts
Discussion Starter · #1 ·
Haven’t had any problems until now. Went to start the car all it does is a single click no start then gauges cycle to max then back down. Turn the key again no click this time and no start. Then started gear clicks under the driver dash and passenger side fender. Hit the negative battery post and sometime does start and other times it doesn’t.
How's your Mustang now? My neighbor recently acquired a 2002 V6 with a similar starting issue. It turns out to be a bad negative cable. We'll deal with the transmission replacement after installing the brake pads and tires from 4Wheelonline, plus the alignment.
1 - 3 of 3 Posts
