1 - 3 of 3 Posts
Discussion Starter #1
When driving in very warm weather the car over heats and will dump coolant when I stop , I have changed the thermostat and it happened again. Seems to happen at +27 degree Celsius weather.
Is it actually overheating, or just venting coolant? If it’s just venting coolant, you may need a new cap.
If it’s really overheating, you’ll have to track that down. Determine if it’s an air flow problem or something else (cooling fan issue, or materials blocking the air from passing through the radiator).
That’s a place to start checking ...
  • Like
Reactions: Kimberly
Super Moderator
Most likely the intake is warped or cracked under the coolant crossover or the rear coolant nipple.
1 - 3 of 3 Posts
