1 - 6 of 6 Posts
Discussion Starter #1
Okay well in the summer i turned on the car and it would be fine its winter know and i start my car and there is clicking Noise coming from the middle part of the engine im not sure what to do should i get the mustang changed someone help me
It's sound like a lifter is acting up when the engine is cold. To fix it right, you need to have the lifter changed out. Some times a good oil change will help this problem. But thing to remember is, if it's a 2008, I would take it to a Ford dealer for warranty work to be done on it. If you add anything to the engine, Ford can drop the warranty.
It' is probably normal fuel injector noise. The plastic intake manifolds seem to make the noise louder than what you would expect.
It sounds Like you are noticing lifter noise.....It is more noticeable in cold weather due to your oil being thicker prior to warming up the engine.
1 - 6 of 6 Posts
