1 - 17 of 17 Posts
Discussion Starter #1
Here is a video of a persistent noise that I can't seem to diagnose, I was hoping you guys could help me. Strange noise from 2013 v6 mustang - YouTube this is an actual video of the noise. The second half of the video is where it can really be heard as I set my phone behind the front drivers side wheel and give it a few revs. The noise perks up as it falls back to idle below 1k. This noise occurs from about 68-76 degrees F and is about as loud as an iPhone ringtone at three quarters volume.
Thanks in advance
-FF
Discussion Starter #3
Yes, it was on at the time. Next time the noise comes up (too cold atm) i'll try turning my AC on and off to see if that stops the noise.
ebgonzalez1 said:
It is your flux capacitor
Lmfao! Mine sometimes does it but not as loud and my ac is off, Ford put some silicone I think they said on the belts and was good for a little while but I still sometimes here it!
Discussion Starter #9
Yeah it was definitely my AC. Just replicated the sound and turned by AC off and it went right away. Turned it back on and it started back up after a small rev and a few seconds. Thanks guys, I'll have my dealer fix it when I get my free oil change from them!
Does your ac every stop blowing cold air when its running? Mine will every once in awhile. Of coarse when it was at the dealer it work fine and they said it was working o.k,
The AC will stop blowing cold air if you really get on the gas. It is normal, for Ford atleast.
That's what they also told me but it happens under normal driving conditions......not quite sure what it could be, I love my car so as long as it doesn't get any worse ill live with it if I have to. I don't have time to make multiple trips to the dealer but I will if it does get worse!
Hi MrMike; my 2013 V6 also will stop blowing air "hard" in the hot summer when on the freeway or stop and go; only "sometimes" when it feels like it. It also does it when its pushed hard, but that part was told to me as normal.
Let me know if you find out more about this, but being your in Canada, guess its cold where your at also ;)
Art
Art
Lol, yeah cold right now but I plan on bringing it back in come spring time.ill have to take a day off work because if I just drop it off ill get the, " we let it run for an hour and everything is normal" speach. : (
I think it is a HVAC duct/door issue. One guy from Oki had his doors bangin' on him making noise. When I saw/felt it happen the second time, it was like AC was blowin' on the defroster vent up to the window, but not out the vents at me.
I have also read that before....do you know if its a big fix?
1 - 17 of 17 Posts
