The driveshaft part is true. Only the stock 17" tires would have problems above that speed. Others would be fine. Get a aluminum driveshaft+tune and I am sure you could get 140+.NicholasP said:The drive shaft will blow up as well as the tires
Drive shaft fails at 136mph. The stock limit on my car was 120 I raised it to 125.BlackedStang said:The driveshaft part is true. Only the stock 17" tires would have problems above that speed. Others would be fine. Get a aluminum driveshaft+tune and I am sure you could get 140+.
Yea once u get the drive shaft you can remove the speed limiter entirelywinkawak said:my advice is get an tuner to remove the speed governor and get an aluminum driveshaft from AM. you should be good to go on a track of course lol
Ur top speed will depend on any mods you've done. Prolly like 145 if you have my headers, xpipe, mufflers, CAI, tune possibly moremrkrabz said:So I found a aluminum drive shaft on AM for about $600, getting that would fix the speed issues? (I have v6 performance pack) What do you think my new top speed would be? It also states that the drive shaft would improve acceleration, which is a plus.
A. When did he say he would be doing this on a public road.SpectorV said:A. You really have no business ever going that fast on a public road
B. The tires are probably not rated to go above that
Where else will you be going faster then the top speed limiter allowsBlackedStang said:A. When did he say he would be doing this on a public road.
B. He has the performance package with upgraded tires that are good for 150+ MPH.
Under your rules, there no point in any car that goes over 70mph. Is that correct?Originally Posted by BlackedStang
Thank you, someone who understands.A. When did he say he would be doing this on a public road.
Understands what?mrkrabz said:Thank you, someone who understands.
Also, higher top speed is accompanied with higher acceleration a lot of the time.
Understands that just because I want to have a higher top speed on my car, doesn't mean that i'm going to be pushing that speed on the streets. I never said, "113 isn't fast enough for me on public roads", all I asked was why it was limited to that, and how do I get it to go faster.Understands what?
Answered and answered.mrkrabz said:Understands that just because I want to have a higher top speed on my car, doesn't mean that i'm going to be pushing that speed on the streets. I never said, "113 isn't fast enough for me on public roads", all I asked was why it was limited to that, and how do I get it to go faster.
Have you ever heard of a "race track"...deadsp0t said:Where else will you be going faster then the top speed limiter allows
I don't recall any new 6's breaking that on the strip.. :bad:
I'm very familiar with VIR..BlackedStang said:Have you ever heard of a "race track"...
---------- Post added at 09:39 AM ---------- Previous post was at 09:36 AM ----------
When car and driver took the 2011 Mustang V6 around Virginia International Raceway they were hitting the top speed governor for more than 15 seconds per lap. A drag strip is not the only place you can go over 100+ MPH legally...
THIS... I cant say how true the statement "there seems to be a lot of theories surrounding top speed and safety on the new 6's" is... There are multiple theories about when your drive shaft will break and what tires are rated to. On the Evolution, most stick with 125MPH being a breaking point but as you can read some think it is more than this and others lower. On other forums people continue to disagree and to be honest Im not sure that anyone has put the real leg work in to find an answer backed by Ford. Honestly brother, your SAFE bet is to leave that governor be until you put in the leg work yourself and get an answer that you could have total confidence in. After all, if your drive shaft were to snap at 125, you have no safety hoop to keep that shaft from digging into pavement. There is a very real possibility that it will catch an edge and sent your car our of control... at best you snap a shaft and maybe do some damage to the rear end or transmission. At worst, you can kill yourself and anyone else near you on the road... I respect that you just want the best performance from your car, but please, everyone, take the safest route for yourselves and the other drivers on the road. None of us want to see any other person or car damaged in our never ending quest for positive G force.Answered and answered.
In the interest of your and the publics safety I suggest you contact a tuning expert locally or someone like AM to be sure you get the most up to date and accurate info available as there seems to be a lot of theories surrounding top speed and safety on the new 6's.
