I have the 2011 shop manual, has no schematic. I've looked at 100's of schematics from all kinds of cars, but am unsure if there is anything besides the the inlet/isolation and outlet/dump valve on our cars due to traction control. I know there is a pump, but also unsure of there is an accumulator and where in the circuit it is.
I bought AutoEnginuity to bleed my ABS, which is very soft after brembo swap, even after 3 full bleeds (and going out on road and getting ABS to kick in before 2 of them). It did not appear that MC went dry (took avery long time to get one of the banjo's back in though), but I am also going to pull that and bleed it first. I can feel brake pedal bottom out on floor if I push hard enough (brakes still work just OK, but pedal travel is huge)
Anyway, AI does not have an "ABS bleed procedure", it allows you to manually switch the pump on or off and seperately switch the state of each valve. Would like to see schematic in case there is something unqiue.
My thought was leave both valves open using pressure bleeder, then crack bleeder, then close bleeder. Turn on ABS pump and then crack bleeder again. Any thoughts on a bleed procedure??
