1 - 4 of 4 Posts
Discussion Starter #1
Hi,
I have this problem since few days. The left door window doesn't slide into a metal holder in the convertible top while rising up after closing the door. If I push it - it slides inside.
I have dismatled the door side but there is no way to adjust it there (it is only up and down).
Did anyone have this issue before?
Have you tried resetting the window calibration function? I think you run it all the way down and hold the switch a few seconds longer, then run it all the way up and hold the switch again for a few more seconds. Either that or you do it in reverse order.
Sent from my iPhone using Tapatalk Pro
Discussion Starter #3
Nope it's not this issue. The window goes all the way up after closing the door but it doesn't fit the holder in the covertible top. I made short video. First is when i close the door normaly and the glass doesn't slip into its place and secondly I push a glass towards car and it goes where it should.
1 - 4 of 4 Posts
