1 - 1 of 1 Posts
Discussion Starter #1
https://www.youtube.com/watch?v=akD2bUPW2k0
Replace your 2015-2016 Shelby GT350 factory shift knob with a high quality, genuine OEM Ford Shift Knob. Featuring a leather grip, the OEM Ford Shift Knob will provide you great comfort when you're going through the gears.
If the factory shift knob in your Shelby GT350 broke or was damaged by accident, this genuine Ford GT350 Replacement Shift Knob is what you need for a high quality repair. This OEM Ford Shift Knob features a leather grip to provide you with comfort when you're going through the gears. The knob is accented with a silver face and a red trim and shift pattern that will add a subtle detail to your interior.
Ford specifically engineered this Replacement Shift Knob to work with the GT350's pull-up style reverse lockout mechanism. This prevents an ugly gap between the bottom of the knob and the top of the factory shift boot.
Made to the original factory specifications from OEM quality materials, this GT350 Shift Knob is a direct fit OEM Ford replacement part. This shift knob will provide reliable maintenance-free operation. Genuine Ford part - FR3Z-7213-C.
This GT350 Replacement Shift Knob features a 10mm x 1.25 thread pattern, so no adapters are required for installation. Simply unscrew your old factory shift knob and screw the your new GT350 Knob on in its place, installation couldn't be faster or easier.
This genuine Ford GT350 Replacement Shift Knob is specifically designed to fit all 2015 to 2016 Shelby GT350 and GT350R models equipped with the Tremec 3160 6-speed manual transmission and the stock handle with a 10mm x 1.25 thread pattern.
Technical Note. This GT350 Shift Knob is not a direct replacement of the factory shift knob in the V6, EcoBoost and GT Models as they feature a 12mm x 1.25 thread pattern. However you'll be able to install this knob in those vehicles by removing the retainer clip, drilling out the threads with a 7/16 inch drill bit and tapping it to a 12mm x 1.25 thread pattern.
Fitment: 2015 2016
Item #392958
MPN# FR3Z-7213-C​
1 - 1 of 1 Posts
