1 - 11 of 11 Posts
Discussion Starter #1
Is anyone else having their handbrake go up just a lil but when driving that it makes a red warning at you. If so how have you fixed it?
No issue here, I'd take it to the dealer as well I'm sure it's a quick fix
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Super Moderator
w/o insulting are you sure you're not hitting it with your arm/elbow/other body parts?
I also have the pp. mine feels like the boot is to tight. It pulls up just a little bit and never fully sits down unless you push on it. I'll prob have FORD take a look at it tomorrow while my work truck is being serviced at Chevy
Yes it's fast, no you can't drive it.
2015 GT handbrake
I felt that the hand brake on my 2015 GT didn't go up far enough either, but I usually get it up a couple clicks. Haven't experienced any "red warning" though. Not much help, huh?
Yeah it feels like that at all time. Seems there's just a little pressure that makes it go up a little. I just have to give it a push down and light doesn't come on. Definitely same thing you're describing. I have base model. It doesn't bother me so I'm not wasting a trip to the dealer. I try to avoid going to dealers at all cost honestly.
Yea even in my '10 my knee will occasionally rub against the e-brake lever just enough to raise it to where the red light and audible alert sound. Simple just push it back down.
I have had enough with the e break in my gt pp when it engaged after hiting a pot hole. I'm at my dealer and it would seem this is a growing issue and they know how to fix it. I'll update with the fix after I get it back. I wonder if it's going to lead to a recall?
So it's all fixed. I included the receipt for all that wonder the technical explanation. In a nutshell they took apart the console and adjusted the cable. Apparently the ratchet was too tight and cause the cable to bind? All I know is the cable is super tight and I can't pull the break nearly as far as before. And it locks the tires stiff.
When I press it down it comes up a tiny bit, annoying but no light comes on.
1 - 11 of 11 Posts
