1 - 3 of 3 Posts
Discussion Starter #1
Hey guys I've been searching and searching for this. This is what I've gathered from other forums. The 4 piston ford calipers will fit with little modifications, you will need 14 inch brembo rotors from the 11-14. The 15s have a different offset so won't fit. You will need to get 9/16 generic ID washers or the caliper won't sit right and will look like this 1469470126690.jpg with the washers it will correct and fix that problem. 1469470418829.jpg . Another issue would be getting a different brake line forgot what brand and will need to be trimmed to make it sit flush 1469470690295.jpg 1469470710782.jpg other than everything should fit fine. Again this is what I've gathered from a lot of forums and would like more info on this and help other fellow forum members go this route that's looking for a better brake set up for cheap as it will only cost between 350-500 for everything.
Sent from my SAMSUNG-SM-N915A using Mustang Evolution mobile app
1 - 3 of 3 Posts
