1 - 11 of 11 Posts
Discussion Starter · #1 ·
I am picking up a trick flow street burner top end kit. Already got a 70mm tb and a 75mm maf calibrated for 24's. Which brand of injectors will work best on the twisted wedge heads using the stock fuel rail?
Never run your injectors at more than 80% duty cycle. That being said you MIGHT be able to get away with 24s but you can save yourself the hassle and get some 30s... wouldnt have to worry until you stroked or added
1 - 11 of 11 Posts
