auto or manual? you will also need to either swap rear ends to an 8.8 or swap to a limited slipI have a 2001 Ford mustang 3.8. I want to Change gears to 3.73. I have 18x8 tires. How bad will speedometer be?
then you would want the recal...autos are touchy when it comes to gear changes...if it was a 5 speed adjusting your speed would be fine, but not with an auto...either buy a tuner or pay for the recalAuto. I will be getting a Ford racing traction-lok
yes sir. also the ford racing tlok is no longer being sold new. if you are buying online the only choice you have is the auburn LSD.Sweet. Would sct 3015 work well
yea it's a bummer. if you can find a GT rear off Craigslist go for that. a bit of a more solid rear end then all you need is the gears, gear oil, and the install kitNot Amazon, www.Stangmods.com
