1 - 20 of 24 Posts
· Registered
Discussion Starter · #1 ·
I got a 2004 3.9L auto and was wondering what the changes were between mine and 3.8L. If I am right 3.9L is the volume of oil that runs through the engine. If there's 3.9L in one that means I got .1L more running through mine than the 3.8L meaning it's bigger, doesn't it. I really don't know and that's why I'm writing, see if someone can correct me.
· Registered
Discussion Starter · #2 ·
Most say there's no difference in performance, but I wonder why wouldn't there be if engine is bigger.
· Registered
Someone told me here, that it had to do something with ford making a freestar that had the same engine in it, so they had to swap it out so it wouldnt be the same. Also the main improvments that american cars do is bigger so there was bound to be a bigger engine in this year after the 3.8 mustangs after awhile.
· Registered
I work for Ford and they sent us a special memo stating that it had blah.blah.blah reasons for making 3.9L but none of the reasons had any performance benefits. All of the Ford plants in the world have assembly lines that with a few clicks of a button can produce any vehicle in the Ford lineup...kinda cool! Basically it is easier and more cost effective to run the 3.9L in the Freestar AND Mustang instead of 3.9L Freestar and 3.8L Mustang...especially since they are basically putting the explorer v6 in it next year. a temporary solution for production issues between vehicles.
Ted
· Premium Member
Well thanks for the compliment
we might not be light but we are at least 500 lbs lighter and way more aerodynamic. The only way you are going to make that up in a van with the same HP is to put a nitrous kit on it or force the mustang to add 500 lbs and make it drive in reverse!!!! Not to mention the van has front wheel drive and has not nearly the gearing for acceleration.
· Registered
Freestars Rule!!!
J/K Ive sold many of both and would have to say a v6 stang is no slouch
50%car/50%driver
· Registered
But 04 Freestar could still smoke those POS pre-99s. :cool:
They also have 264lb-ft of [email protected]. Compared to the mustang's 225. It wouldn't be hard to get one to outrun a mustang.
:cool:
· Registered
Freestar What?
not to throw a stick in the discussion
3.9L Freestar V6 193 Hp @4500RPM/ 245TQ @3500RPM
4.2L Freestar V6 201 Hp @4250RPM/ 263TQ @ 3650RPM
3.9L Mustang V6 193Hp @5500RPM/ 225TQ @ 2800RPM
Freestar Curbweight:4263-4396lbs
Mustang Curbweight:3070lbs
Info Straight from the Ford Sourcebook
· Registered
Ford States Bas Model Curb Weight (Approx. Lbs.) 3070 coupe 3254 conv.
asterisk #3 states base model with manual transmission, gt model with manual is 3317 coupe and 3429 convertible.
This is the info Ford gives dealers directly to train off of and research our products. if it is totally incorrect it is none of my doing.
Don't Shoot The Messenger, Man!
Ted
1 - 20 of 24 Posts
