1 - 20 of 37 Posts
If you have a 65 with a 302 then you have a mismatched car. The 302 came out in the Mustang in April 0f 68 after the strike. Other then that what help do you need?
Discussion Starter · #5 ·
Ok car ran great , start the other day and it won't run . You crank and crank and as long as the key is on and your still cranking she will spit and sputter. But of you crank it like you should it does nothing but a little spit and won't actually run . Also it blew fuel out and caught fire so I have no clue it's all timed,has fuel,it's getting fuel and I have spark that is why I said help lol
Sent from my SM-N920V using Mustang Evolution mobile app
Can you give us some more information about the motor?
Is it stock with 2brl or 4brl and what carb?
Does it have stock single point ignition or has it been changed?
Does it have the stock fuel pump or an electric one?
Did it actually spit fuel back through the carb or did it backfire through the carb?
Discussion Starter · #9 ·
78 engine
302
Hei distributor
Stock pump
It back fired once
It Spit once
78 engine
302
Hei distributor
Stock pump
It back fired once
It Spit once
What kind of carb do you have, stock or Holley or ???
Did you buy the car with HEI or put it in yourself?
It's either the ignition or carburetor although I wouldn't rule out the fuel pump.
Crank the motor over until TDC...top dead center on the #1 cylinder...check to make sure the timing pointer at the harmonic balancer is within 4/8 degrees of the 0 marker on the balancer.
Also take the #1 plug wire off the plug and place it near the block...crank the motor over to see if there is a spark/arc.
Take the air cleaner off and look down the carb while pulling the throttle manually...with the engine off of course.
Do you have a vacuum advance on the distributor...make sure it is connected at the distributor and carb and that it's not cracked or broken.
Discussion Starter · #12 ·
Holley 500 cfm 2bbl
I have spark
Did the TDC
And have fuel going in carb and out carb that's why I am lost
Sent from my SM-N920R4 using Mustang Evolution mobile app
This carburetor is probably one of the hardest Holley carbs to tune and get right especially on a stock motor.
First, if you had the backfire before the fuel started coming out of the top of the carburetor I may suspect the power valve is ruptured.
Have you checked the fuel float level on the carburetor...it should be set to lowest point in the sight hole although without running the motor or an electric fuel pump to build fuel pressure this could be hard.
One last thought is the the needle and seat is stuck allowing the bowl to fill completely and dropping fuel into the carb...just some thoughts.
I'm not sure how old the carburetor is and if it's more than 5/6 years old I'd buy a rebuild kit and take it apart and look very closely at the power valve and needle and seat...IMHO
Discussion Starter · #16 ·
So here is what I have come to figure out , when the accelerator is pushed the accelerator gasket locks up and we'll when you remove the bowl the gasket moves freely and gas will come out when you compress it and we'll what it is acting like is so much pressure builds it cannot push through idk
Did you buy this carburetor and put it on or was it on the car when you got it?
I assume you are talking about the carburetors accelerator pump diaphragm, as there is no gasket because the diaphragm is the gasket between the accelerator bowl and carburetor body.
Is the diaphragm in backwards? When you push on the accelerator does the accelerator pump arm push down and move the lever that pushes the diaphragm up. You should be able to do this with your finger.
Take a look at the picture and let us know which part is not compressing.
Click on the picture once and then once more to make it larger.
Discussion Starter · #19 ·
The lever does everything right but when the bowl is full it's like it sucks the diaphragm up and don't let it down spring and everything inside is good
Ok, I assume you had the carburetor off the car. You take the the diaphragm out...I assume you checked for any tears or breaks...and then put it back in...still off the car....and push the throttle and it pushes the lever up which moves the diaphragm...right...at this point everything works?
So, you put it back on the car and try and start it...the carburetor is now empty of fuel...did you check the sight plug on the side of fuel bowl to make sure the fuel is at the bottom edge of the sight plug...and when the carburetor fills with fuel and you press the accelerator and the throttle lever will not push the diaphragm up like something is holding it from compressing...and fuel is still coming out of the carburetor into the intake manifold?
1 - 20 of 37 Posts
