Swap day 06
Had to shave 5/16 inch off the transmission spacer, install three 0.187 throwout bearing spacers, and drill new holes in the transmission cross member, but we finally got the transmission in the car for good, and measured for the driveshaft.
Today, we're going to modify the passenger side header so it clears the bellhousing (it just barely touches when it's bolted up. Once that's resolved, we can weld the v-band collar to the collector and send the headers out for ceramic coating.
Once that's done, I think we're going to tackle the fuel system changes.
Swap day 07:
Drive shaft is in
Exhaust is done - headers go out for coating on Monday
Headers prevented "normal" use of dipstick, so we had to be the crap out of the tube
Top and bottom radiator hoses came from a Fox mustang
We moved the radiator a bit farther forward to resolve a clearance issue with the water pump and the fan. Fortunately, all we had to do was lossen the bolts that hold the top brackets down and pull the radiator back. This gave us about 1/4 inch of clearance.
Mounted carburetor and installed linkage. We're having a problem with the throttle cable popping off the throttle ball at full throttle. Gotta think on it some
We had to modify the air cleaner base so that the air cleaner would clear the firewall. This entailed cutting the carb hole out with more material on one end than the other, turning it around, and welding it back into place. Then, we made a "S"-shaped stud to accommodate the offset.
We have 5-7 working days before we get the headers back from the coater, and that will give us time to finish running the fuel line, mount the expansion tank, and do the electrical stuff. By the time the headers come back next week, we should be ready to start the engine for the first time.
Update - Day 08
Mounted the expansion tank in its new location.
Had to fabricate a bracket for it.
We also mounted the coil (also on a custom bracket) and the A/C compressor.
Finally, I built and installed the plug wires.
---------- Post added at 07:42 AM ---------- Previous post was at 07:42 AM ----------
Swap day 09:
We got the tee for the lower radiator hose and installed it. I was amazed at the quality of the part. It's a billet piece with no welded-on stuff. Primo gear. All we have left on the cooling system is an overflow hose connection. That should be handled today.
The fuel lines have been plumbed. I paid half of the cost of a "Koul Tool" for the shop. This is a vice-like machine that allows you to put a push-lock hoses onto an AN fitting in less than 2 minutes (less than 30 seconds if you have air tools). Believe me when I say that you don't want to be without this tool if you're doing push-lock lines. We're still waiting on an aluminum plug for the fuel pressure regulator, and when we get it (should be today), the fuel system will be done. The shop guy wants to weld a couple of fittings for the fuel pressure gauge, and that should also be happening today.
I'm still waiting to hear if we're going to get the headers back today.
The schedule for the weekend includes:
- Finish up the cooling system
- Finish up the fuel system
- Finish up A/C compressor install
- Install air/fuel gauge in a vent pod
- Install the MSD box
- Weld O2 sensor bungs into x-pipe
- Install headers and x-pipe for the final time
- Install TPS sensor on carb
- Install temp gauge sensor
- Install oil pressure sensor
- Start electrical work
Another aspect of this swap that I haven't yet mentioned is the work of a tuner to turn a bunch of stuff off, as well as remapping other parameters to allow the ECU to function without blowing its little electronic mind. As I get details, I will write it down for the sanity of those who follow in my footsteps.
Swap day 10
Accomplished:
- Install headers
The lower radiator hose tee installed and connected to expansion tank:
The headers came back from the coating shop - $190 including tax.
The headers installed:
Swap day 11:
Update from yesterday:
- The exhaust is finished and permanently on the car
- Power harness is modified and wired up (including starter and alternator. We ended up with only 5 or 6 wires not directly related to power being needed, because most of the harness involved with the power steering rack (that is no longer present).
- MSD module and coil are wired up
- A/C clutch harness is run but not connected yet
- Transmission clutch has been bled and we have what appears to be proper throwout bearing operation
- Battery is back in the car
We now have enough wiring installed to start the car, but we didn't have the regulator plug to finish the fuel system (will have that Monday), and I'm having a bit of difficult finding a 3/8 NPT 90-degree fitting with a 3/8 hose bar on it for the PCV valve (all other solutions have been too tall). I'm gonna hit Lowe's and Home Depot today to see if they have anything.
We still have to wire up the transmission (speedo and reverse solenoid), and tackle the ECU harness. We've identified all of the connectors, and we have to tread carefully when removing stuff because we want to make sure that what we remove doesn't somehow have an impact on what we actually need to keep (throttle position, cylinder head temp, crank position).
BTW, I used the Ford Service Manual for a 2011 Mustang to identify the wires, and some of the wire colors changed for the 2012 model year.
In short, 99% of the nuts and bolts stuff is done, and we're down to the electrical stuff. Not bad - two weeks in and we're almost finished with what I would loosely call a significant swap. Sorry for no pictures today, but all of the wiring is pretty well hidden, and the rest of the engine bay still looks mostly like it did the day before.
