Everyone seems to be really scared about changing out their stock 3.27 gear with a steeper gear like 3.73, 3.90, or 4.10. I elected to go big or go home and went with the 4.10s. And I'm so happy I did! Here's a video to put to rest all the stories about how terrible the gas mileage is and how much it affects your car... This is a video of me on the interstate running at 65mph, 70mph, 75mph, and finally 80mph. The speedometer and RPM gauge is all correct thanks to my tuner.
Don't fear the gear! 4.10 is amazing!
4.10 Gear RPM/Speed Example Video - YouTube
Also I would like to add that for an automatic-equipped vehicle, the RPMs with the 4.10 gears will be 100-200 lower than a manual-equipped vehicle. This kinda goes for all gears. So while a popular choice for manual cars is a 3.73, people whom have autos will feel a similar gain in power from a gear much steeper like a 3.90 or 4.10.
---------- Post added at 01:33 PM ---------- Previous post was at 01:25 PM ----------
And one more thing! People say that the steeper gear you get, the less top-end you'll have in terms of MPH. This is completely false in so many ways- especially if you have a brain and can think. With a relatively stock car, you reach 5th gear at around 105mph if you're going all the way through the RPM band. Then when you shift into 5th with stock 3.27s, your RPMs hit around 2k-2.5k. The powerband is around 3k+, but seeing as how 5th is an overdrive gear, it's very difficult for your car to get into peak RPMs around 4k-4.5k and you usually end up hitting maybe 110 then acceleration almost stops.
However, with 4.10s, at 105 I hit 5th gear and my RPMs are already right over 3k, and then soon they're over 4k and I'm going around 125, then at 5k I'm at 135, and I've gotten up to 143mph at around 5.5k. When I had stock 3.27 I was maybe getting 120 if I was lucky. With the steeper gears, the engine is allowed to work at a more efficient RPM and doesn't get bogged down.
So yeah... The only downside to steeper gears is:
1) Lower MPG(but only barely if you drive nicely)
2) You burn out a lot
3) First gear becomes pretty useless.
Upsides:
1)Accelerate like a bat out of hell (versus stock gears)
3) Your engine works at more optimal RPMs in pretty much every gear
4) City driving is easier because it takes less effort to start rolling
5) Passing on HWYs and Interstates is fun/safe again.
6) There are more, but I gotta get going to work. Lol Can't wait to drive my car!!
