so i have 3:55 gears right now and i run 13.5 seconds on the quarter mile. If i install 4:10 gears will i run 13 flat? someone told me i will drop a half second. is that true?
that ones hard to say. imthink there is a possiblity he can drop that much with traction of course. imwould definitly say it if he had 3.27s. i was pretty suprised when 90mustanglx drop .6 or .8 just doing a manual swap.deadsp0t said:A half second sounds like a stretching of the truth.. You should drop some but not a half second.. If its not an issue already, traction/launch will become tricky. With a great launch and traction .3 tenths 'might' be had.
Auto to manual is a whole different game because the auto weighs like an anchor and is stupid inefficient, at least mine is lol but the ratios are close. It's like a T5 with no 4th gear loldreamstang said:that ones hard to say. imthink there is a possiblity he can drop that much with traction of course. imwould definitly say it if he had 3.27s. i was pretty suprised when 90mustanglx drop .6 or .8 just doing a manual swap.
Good point. The faster autos that most drag racers prefer are high performance ones. Not the aod unless built. :good:deadsp0t said:Auto to manual is a whole different game because the auto weighs like an anchor and is stupid inefficient, at least mine is lol but the ratios are close. It's like a T5 with no 4th gear lol
But your correct if it were a larger jump in ratio it'd likely knock down even more assuming traction was good.
