1 - 20 of 34 Posts
· Registered
Discussion Starter · #1 · (Edited)
Steeda Shift knob, red the unpainted style with the S machined into the top and black rubber around the grip. $25 +shipping
Steeda double hook clutch quadrant $25 +shipping
All engine parts come from a 2000 4.2 F150 motor in good working order.
4.2 F150 Torque converter, looks to be in good condition.
$65+shipping OBO
Split port heads with springs and valves $250+shipping
pushrods and lifters could be included for a little extra.
Split port lower $150+shipping
Split port Upper $200+shipping (supposed to be better then the 3.8 upper, but won't clear the factory hood)
Stock 4.2 pistons and Rods
SOLD :)
4.2 cam (good as a cheap upgrade for a 3.8) $50+shipping
4.2 TB 60MM $60+shipping
I'll half shalft it for $15 more
'00 TB gasket $10
Various other parts, alternator, fuel lines&rail, waterpump, headers, IAC, EGR, etc.
PM if you're interested in any of the odds and ends and we can work something out.
· Registered
Discussion Starter · #2 ·
anyone interested in making any offers on any of this stuff?
· Premium Member
i wish i had the $ for the upper and lower, since i hope to build a 4.2 turbo this coming year, but right now i can't afford it :(
· Registered
Discussion Starter · #4 ·
Well, the way it's going I may still have them
· Registered
Discussion Starter · #6 ·
Well, eventually I'll have an extra block from my 3.8. The 4.2 and the 3.8 use the same block
· Registered
yeah i know...........im looking for a good used f150 short block.
i already my split port heads and intakes.
im trying to avoid stroking but i may have to
· Registered
Discussion Starter · #9 ·
1995whitestang said:
you happen to have a 4.2L crank to go with those rods/pistons?
Well, I do, but I'm going to be using that for MY stroker. :)
· Registered
Discussion Starter · #10 ·
bump
· Premium Member
Can you take a picture of everything and send them to me. I need to piece some stuff together.
· Registered
Discussion Starter · #12 ·
Currently all of it is stil attached to the motor. I haven't taken it apart yet.
Um... Let me know if you want just a pick of the motor. I can probably con my friend into taking a digi pic for me.
· Registered
Discussion Starter · #13 ·
bump
· Premium Member
So do you still have all this attached to the motor still?
· Registered
Discussion Starter · #15 ·
No, the Heads and intakes have been pulled. I still have them but it's apart now. The fuel rail is off. I should be able to get a digital pic by next week.
I can get a pic of the fuel rail assembly for you.
· Registered
Discussion Starter · #17 ·
the lower intake is the same as the 01+ lower intake, with the IMRC's, the upper is totally different. It will bolt on, but won't clear a factory hood, from what I have read. The heads would bolt, and are also split port. The waterpump looks to be exactly the same too. The TB will bolt on to a 99+. All the steeda parts are for mustangs.
· Premium Member
The 4.2 cam will net you minimal results, but they are still slightly better
1 - 20 of 34 Posts
