1 - 18 of 18 Posts
Discussion Starter · #1 ·
My 96 gt is running rough and missing. I can smell gas on the driver side of the engine. I don't think it's the COP's or the 2 coil packs themselves. Maybe bad plugs? Any suggestions? Also about a week ago I was driving home from work, went to throw it into neutral and the car died. Started it back up and it ran like it does now. About 2 miles down the road it eventually straitened itself out. Help?
Discussion Starter · #3 ·
It does have an exaust leak. Right at the flange where the intermediate pipe meets the manifold pipe. Couldn't line it up right when I replaced my clutch. Is it possible the exaust leak could make it run like that???
Very possible because I was trying to figure it out then I told myself to just listen so when I really started paying attention I herd like a flutter noise so got under there and seen I was missing a nut on each side and it did have a bank 2 lean code. So I went to lowes got some nuts and some lock tight and do believe I fixed it... It doesn't die when coming to a stop anymore when in fact it did it a lot...
---------- Post added at 06:56 PM ---------- Previous post was at 06:55 PM ----------
Oh and not to mention I run 100 shot on it too so it's not been fun not being able to use it...
Discussion Starter · #5 ·
I got to lookin more and cylinder number 8 had coolent in the plug well where the COP goes in. I had to replace the intake alittle while ago due to the spout on the back breakin off and spewing everywhere. I'm thinking it fouled the plug????
Had the same problem when I changed the intake on my 98. Change the plug or clean it real good and get some deelectric stuff and put some in the plug boot and on the end of the plug. It will keep it from fouling out in case there is some coolant left over. It will hold til it drys all the way out. I use deelectric every time I change my plugs anyways.
Its Definatly in the back near the firewall. That's why I'm thinking it's that 8th cylinder.
On the driver or passenger side? Never mind lol read more its number 4 if its by the heater core though
Needs to be fixed!!!
---------- Post added at 07:59 PM ---------- Previous post was at 07:58 PM ----------
Needs to be fixed....
Discussion Starter · #14 ·
Just replaced the COP's today. Still running rough. Unplugged the down force sensor right before the intermediate pipe meets to see if it would reset the computer to run differently and got nothing. Any other suggestions? Maybe a dirty fuel filter?
1 - 18 of 18 Posts
