1 - 3 of 3 Posts
Discussion Starter · #1 ·
Hi I have a 302 engine in my bronco I have some questions I got my heads and valves done and it's time to put them back on my truck but I don't know how to set the rockers or do the valve lash if anyone has done it befor please let me know how to do it thank u
When I rebuilt my heads, I didn't even adjust valve lash, I just torqued the rocker bolts. I haven't had any valvetrain issues at all (yet).
---------- Post added at 09:00 PM ---------- Previous post was at 08:59 PM ----------
But, you move the engine through its compression cycles and at TDC with no pushrod pressure you spin the pushrods and tighten in 1/4 turns until it (pushrod) won't spin.
---------- Post added at 09:01 PM ---------- Previous post was at 09:00 PM ----------
I believe.
It depends. Are the rockers stud mount or pedestal mount? Stock 302s are pedestal mount so you would just torque them down to spec (25 ft lbs I believe). Can't quote me on that. You still want to take the pistons to TDC to torque each one. If they are stud mount you take the approach mentioned above, spinning each pushrod till there is tension then continue 1/4 turn and lock down the rocker.
1 - 3 of 3 Posts
