1 - 4 of 4 Posts
Discussion Starter · #1 ·
Ok i have couple things i have a 5 speed and thinking of goin automatic other than needing obvious trany,converter, cooler, flywheel and shifter is any thing else Imma need like will my driveshaft for my t5 fit the c4 and would a stock auto shifted fit the stock manual center console id like to interior as stock as possible
Just a couple of things come to mind as I did the auto to Manual swap. You may need a diferent trans crossmemeber, and pedal essembly. The auto shifter will fit the stock console, but you might want to consider a donor car for the miscellaneous parts. That would be the easiest. You might find some place selling a conversion kit, but I have never seen one. Just out of curiosity, why do you want to do that?
Discussion Starter · #3 ·
I have access to several cars to pick parts off of and i have a built c4 from another project i had main reason for doin the swap is for the consistentacy for drag racing ive raced a automatic for ten years this is first five speed I've raced and been running. It for a little over a year and its just not as consistent as a automatic
Gotcha. Well I would say you would be good to go then. If you go along and need something you can probably just pull it off a car
1 - 4 of 4 Posts
