1 - 4 of 4 Posts
Discussion Starter #1
So, still available thru ford, you can buy the 2000 cobra R T-56 six speed transmission. I have have been talkin with a tech at ford and if our motors do in fact have the same bolt pattern as generic ford SB ( i.e 5.0) then it wouldn't be hard at all to bolt on up! Ford offers a 5.0 T56 with a mechanical speedo that SHOULD bolt up to our motors. They also offer a T-56 tranny crossmember that will bolt it up there. It's seems the only issue is the DS.
Discussion Starter #3
I'm lookin into the DS situation. If I'm not mistaken, our cars have a 10-spline input, so does the t-56. It should be a relatively easy mod.
Discussion Starter #4
You can buy the T-56 and the crossmember thru ford racing. The tranny is a bit pricy but if you can afford it, it would be a sick mod
1 - 4 of 4 Posts
