1 - 7 of 7 Posts
Discussion Starter · #1 ·
I have a 1964 ½, Mustang with a 260 V8, with a 2100, 2 barrel carb. Just ran into an issue where the carb does not seem to be getting fuel. I have checked and the fuel pump is working. I took the fuel line off the carb and it has pleanty of gas pumping, it just is not entering the carb. What is the cause of this and what is the fix?
The carb was completely rebuilt about 2 years ago.
I am not a mechanic; I am a parts changer and weekend warrior when it comes to working on cars.
Any detailed help would be much appreciated.
Bartz is right, your needle valve is stuck. It's happened to me more than once with rubber tipped needles. I've replaced them with metal tipped needles or, in the case of my SU's, Groose valves using balls instead of needles.
You need to pop the top off. No problems there, just unscrew the top screws and the lid will come right off. You can replace it easily without affecting your carb adjustments. Check that your float works and the needle valve moves freely.
The needle is stuck in the seat. The needle is operated by the float. Remove the top of the carb, and replace the needle and seat. Also make sure the feed is clear between the seat and the supply line. Either a very small wire or air pressure for this.
on that 2bbl the fuel inlet is a filter , change the filter and see if you get flow. if not unscrew the top plate of carb and spray out with carb clean. if it were me id get a holley 2bbl for it. even a parts changer could rebuild it ....very user friendly
buy a can of carb and choke cleaner, attach the provided red tube and spray it into the fuel intake to clear any blockage. It is designed to do stuff like this and won't harm you engine.
There maybe a filter in the inlet of the carburetor that is plugged.
Or there could be a cobweb from some insect that is blocking the idle circuit of the carburetor.
These are not hard to work on, just get a digital camera and take pictures as you work. A carb over haul kit is not that expensive.
Make sure you have a place to work that will let you find the small parts that fall to the floor.
a carbuerator has a float bowl and a float in the bowl. Its kinda like a toilet. Dont laugh,,, its true.
Look at the water tank in your toilet. It has a float ball. When the water is flushed the ball drops,,,,water comes in,,,the ball starts to rise,,when the tank is full the ball shuts off the water. Same thing in a carbuerator.
I think the float ball is stuck in the ''up'' position and wont let the gas in. Try tapping on the carbuerator,,,it may make the ball drop and let the gas in.
But you are still going to have to take it apart again.
1 - 7 of 7 Posts
