1 - 20 of 24 Posts
Discussion Starter · #1 ·
i have heard that it needs some sanding in fitting for a 2002? if this is true, is it worth the investment?
Discussion Starter · #4 ·
i have CAI, Duals, and im about to install underdrive pulleys....sooner or later i was thinking of throwin on a charger of some sort...after some other mods of course..its all in the future...just thought id do some researching
Porting the intakes will do more for you,
and the 70 takes extensive mods. I did
one for Capt. Kirk :D (silver2000) and he got
post removal and crossover tube work to
boot. He is gonna run an SC with it. But
to add to what these guys said, I would
use it for high RPM 3.8's, power adder
setups and strokers. Most street 3.8's
are fine with a stocker that is modded.
Discussion Starter · #7 ·
what about headers...are they worth the addition for power
HELL Yes!~
on a v6 with very few mods your not gonna see many gains from them
With a cam and porting, I would say YES.
For minor mods, (just boltons) and modest goals, maybe not.
Depends on your budget, and headers are not
a good dollar/HP ratio on near stock cars.
But the LT's and a cam and porting is a great combo!
I completely agree, you'll need a huge air sucking engine to require a 70mm TB.
Like Robert said No cam no Lt's. Dont waste money chasing advertiser claims. Most claims are based on GT's and they use them for V6's and that is a scam!!!
slvr2000stang said:
RGR.
What do you think about LT's with my new setup?
Worth it pre-blower?
Yes, since you are getting the cam, porting, and all that.
But if you were staying NA the cam and or header requirements
would be change, you can do it pre-blower but I would say
you stand to gain minimally in teh pre-blower setup, your cam
has extra Exhaust duration (for the blower) and that plus LT's
will over-scavenge the exhaust a bit, but at this level it may be
a very minimal power (imperceptible) power loss, but perhaps
a noticeable mileage gain!
Discussion Starter · #16 ·
why does the newer model stangs only use the harmonic balancer rather than the entire pulley set the 98s and below use
when i get my heads/cam/intake swaped i plan to go with long tubes and high flow cats and run it out to tips but till then or till you have motor work or a blower heads are worthless.
Discussion Starter · #19 ·
ive looked and all i can find is the harmonic balancer...where can i find the pulley?
1 - 20 of 24 Posts
