1 - 12 of 12 Posts
Discussion Starter #1
What are these and what will they do? Bc I was gonna get 3.73 gears for my car
if you have an 8.8 rear end from a gt then they can work..
well you have to pull a gt rear end and swap into your car to use them, and then even at that those are 3.27 gears which is the same ratio that's in your car right now
3.73's if you do a decent bit of highway mileage
you should be able to determine the gear ratio of your current rearend one of three ways:
1. door tag
2. rear end tag (should say something like 3.L27 if its currently 3:27 gears, if its 3.L55 (3:55's). 3.L73 (3:73's) and so on and so forth. the L indicates locking differential
3. jack up the rear of your car and rotate the tire/wheel one full round and see how many times your drive shaft rotates...you can make a "white out" mark on both to determine how many revolutions.
with an automatic most prefer 3:73's on a daily driver other more aggressive drivers prefer 4:10's.
hope this helps...
1 - 12 of 12 Posts
