1 - 6 of 6 Posts
Discussion Starter #1
Bought a 86 5.0 with a carb. and it has all the vac lines & smog pump want know if I can yank it all off and go simple. Don't seem like the distributor has vacuum?
You can take the smog pump off and bypass it with a shorter belt with no problems. Be careful what vacuum lines you take off and inspect the others for leaks.
Discussion Starter #3
Where should dis vacuum line go? right now goes to some sensor with another vac line that goes nowhere? And is not plugged. It has a holley carb on it now.
1 - 6 of 6 Posts
