1 - 7 of 7 Posts
From personal experience, I can say that I get my best gas mileage with my tuner set to 91 octane Performance tune. 87S and 93R don't do as well. Prior to getting a tuner I got my best mpg using 87 octane.
The higher the octane number the more resistant the gasoline is to combustion and therefore less prone to pre-ignition. Higher octane is generally only necessary for:
A) High compression/forced induction engines, or
B) Engines with stock internals that have the timing advanced a great deal over stock, such as you would get with a custom dyno tune, or a Bama tune etc.
The short answer is 87 without a tuner, 91-93 with a tuner.
YMMV... but this is what I experienced myself.
Use the 91/93, you'll be happier in the end, less problems and issues.:good:
Stock car?
Not tuned for anything higher?
If so don't waste your money on anything higher.
Waste of money unless tuned....
Discussion Starter #7
I filled up with 93 costed me 5 more dollars than usual but not really using less gas plan on getting a tuner
1 - 7 of 7 Posts
