Have a 90 lx with rear five lug disk break set up. Rear is 1 3/4 wider now "I think" n e one know what offset and tire size I need fir street/strip? Have 17Cora r style wheels now and want to go to the weld five star instead hate the 17. Thanks
Rear was in car when bought 8.8 / 373
Standard width rear ends work with a 5.5" "backspace" up to an 8" wide rim. A 9" wide rim needs a 6.0" backspace and a 10" wide rim requires a 6.5" wide rim and substantial inner fenderwell reworking and outer fender lip rolling.
If your rearend is 1.75" wider overall, divide that by 2 (0.875" or 7/8") and add that measurement to the backspaces required that I have shown.
8" Rim - 5.5 +.875 = 6.375" or 6 3/8"
9" Rim - 6.0 + .875 = 6.875" or 6 7/8"
10" Rim - 6.5 + .875 = 7.375" or 7 3/8"
Note: Those will not be a standard backspace for any wheel that I know of, so you would have to go up in backspacing size. to fit a particular rim to the wider rear end/car.
Example: An 8" rim may now require a 6.5" backspacing to fit the car with the wider rear end.
You may not be able to find the Weld Pro Star wheels in the backspace you will need. Whenever a wider than stock rear end is used, it severely limits your wheel choices.
Personally, I would try to find a Mustang width 8.8 to put under the car.
