1 - 11 of 11 Posts
I believe there is complete compatibility from
89-98 but you must use 96-98 heads with a
96-98 lower intake or mod the intakes to fit the
heads, but it is an easy mod. You also have to
use the same year gaskets as the intakes are.
Big Bore and forged pistons, stock (forged) rods :)
High RPM NA use, baby! :D
:arrow: SC crank for sale probably, I could use the $$$
and you could use the forged steel crank strength!
:arrow: I have done lots of measuring and research, I
have found that the bigger bores on a V6 should be very
safe with the proper machining and such, my machinist
has done V6 blocks .060" over and it was great, more is possible.
:arrow: BV heads and a big cam to top it all off! 1.8 RR's
on top of that and the level 2 springs wil complete the pkg.
In the older blocks they had a few extra coolant holes running thru the block and head but a couple were 2 close to the cylinder on the heaad side causing the head problem in 96 they changed the design in 96-97 and futher in 98. Actuall the 98 block is identical to the 99 block minus the new top end stuff
1 - 11 of 11 Posts
