1 - 9 of 9 Posts
Discussion Starter #1
Snapped one on the bolts
today as I was putting the upper intake back on. Can't find them anywhere online. Does anyone have them or know where I can Get them? Was the outside bolt and can not remember if I was the long one or the longer one.
Go to a bone yard and pull one off of an efi Windsor intake. 351 or 302, the bolts will work. :good:
Discussion Starter #3
I will give that a try but mustangs don't last here in the yard. Got to get lucky to find anything left on them and be there at the right time
Banned
there are a few cars with those motors.lincons explorer etc. doesnt need to be a mustang.
---------- Post added at 08:41 PM ---------- Previous post was at 08:26 PM ----------
also check summit racing.i bet they have them.
Banned
Failing to find the bolt you need you can also use some "High Tensile" strength threaded rod and cap it off with acorn nuts.
You need High Tensile strength rod because regular threaded rod is weak and is likely to break when you try to torque it down.
Discussion Starter #6
Yup that's what I was planning on doing if I can't find it. Don't want to go that route but if I have to I will.
Banned
In all actuality the threaded rod will act like a stud and probably hold better than a bolt. At least you lessen the chance of damaging the threads in the lower intake from cross threading and friction galling. :good:
Banned
1 - 9 of 9 Posts
