1 - 3 of 3 Posts
Discussion Starter · #1 ·
The r-134 service port on the passenger fender side and near the firewall pointing straight up with the black cap covering it. I found my leak problem is from there. It looks like a cylinder that can be removed and replaced with the service valve inside. I need help identifying this correct name and where can I find the replacement part on the net? There isn't a ford dealer near me... thanks...
it is not a schrader valve i can tell you that, go to your local ford dealer and most likely they can order it for you or you can call mps auto salvage(all mustang wreck yard) and they can get you the part.
1 - 3 of 3 Posts
