1 - 5 of 5 Posts
Discussion Starter · #1 · (Edited)
Okay all, new to the forum. I picked up a 2000 3.8 5 speed car and immediately wanted a V8 conversion. A friend had a 96 drive train and said the conversion could be done. Cradle in, motor in, Problem is the wiring harness in the 2000 will not plug into the 96 ecm/pcm. Is there an adaptor or what that I need to make this work, Any help would be appreciated.
Discussion Starter · #3 ·
Yeah, everything is swapped out. the wiring harness for the car and the ecm from the donor have the same ends. I believe female, need some type of adaptor.
Discussion Starter · #4 ·
What I found out from Ford Racing is I have to rewire the dash harness to match the ecm from the 96. wire colors may have changed so have to follow the wiring schematics in both service manuals. I will do this.
1 - 5 of 5 Posts
