I wish I did, main focus is get it running then strip down my 96 gt for parts.If u had the extra cash it be perfect time for pi swap.
Thanks, any special tools I should look into?You should get new gaskets (duh), new head bolts, and take your heads to a reputable machine shop to have them checked.
A quality torque wrench, impact gun makes some of the work a little easier. But mostly a decent set of hand tools will get you by.Thanks, any special tools I should look into?
This is the first car I've ever started putting money into.
I tried am, I'll check out summit and cjpony tomorrow, are they any good? I've not heard of them before.Did you try summit? Or cjpony parts maybe or am
Thanks, I'm guessing they can order what I need if they don't have it.3.8 head bolts from most auto parts stores, I went to autozone, just fel-pro bolts will be fine
Yessir, most can get stuff the next day, they also have head gaskets if you don't mind using felproThanks, I'm guessing they can order what I need if they don't have it.
Sounds good, need to fix this soon. I totaled my 96 GT earlier today.Yessir, most can get stuff the next day, they also have head gaskets if you don't mind using felpro
