The battery is fineYou guys probably need new batteries... get em tested for free at kragen... Id start there for sure
I tried unhooking the battery, turning the key on an off rapidly etc. how do I unhook the theft system?I had the same problem the other day.. First time in 7 yrs that I've owned her... I don't really know what fixed it since I try almost everything but I do remember I took the key off the ignition, shut the door and lock it them repeat the procedure backwards
Lamme know if it works for you!
I don't think you can disable that feature since is a module related deal unless you have a rotunda scan tool.. Try locking and unlocking the doors with the key on, I know it has something to do the order you did things(locked it first then shut the engine off then tried to get out with the doors being locked)The battery is fine
---------- Post added at 09:28 AM ---------- Previous post was at 09:26 AM ----------
Looks like ill be taking it to the dealership.. Nothing is working.. Lol thanks anyway guysI don't think you can disable that feature since is a module related deal unless you have a rotunda scan tool.. Try locking and unlocking the doors with the key on, I know it has something to do the order you did things(locked it first then shut the engine off then tried to get out with the doors being locked)
Having it towed to the dealership soon.. Ill ask them about the key. ThanksYou probably just need a new key.
Got it running! I did what you said plus I turned the blinkers on etc lol that is stupid but it worked.. Thanks manYou should give it another try just keep messing with locking/unlocking and the key in the ignition it could save u a couple hundred dlls
Lmao I think I even moved that before it finally started... Thanks manIf you have a tilt wheel, move it in the other direction... I had the same problem with my 99, there is a wiring harness that gets damaged after a while from moving the tilt wheel...
Mine would only start when the wheel was down.
