1 - 12 of 12 Posts
Discussion Starter · #1 ·
1.) Does anyones box slide around in there trunk? If so, what did you use to stop the sliding?
2.) Does a cap do anything at all that could help my system?
3.) Do I need to drill a hole in the firewall for a 8 guage wire or can I run it through another hole?
That's it.
Banned
cap is not useful. Do not buy one. If your running 8 gauge wire chances are your not going to need to worry about lights dimming ;)
I am running 2 gauge to a distribution block and 4 guage to a Directed 1100D . My lights are fine
Otherwise, I've seen people route wire up through the driver door as well. Just under the hood right in the corner there and into the door, then straight down to the door sill and to the back of the car.
hmmm i guess i got lucky. theres a very large rubber boot that goes around the steering column on the eclipse. it has a nice 2" square of rubber that is before the actual shaft for the steering. everyone uses it to run anything they need to into their DSM's with that piece, and it requires no taking apart to get to. i love it, right now, i have a 8ga wire, boost guage hose,4 different wires going through it, and theres room for more.
but on the tbird, it was hell. i had to drill new holes everytime i wanted to add something. now that theres nothing in the holes, when you drive you get hot air from the headers going right through the holes onto youre leg. ghetto heater yo.
1 - 12 of 12 Posts
