1 - 4 of 4 Posts
mine did the same turned out my module went bad $1300 to fix it (I pulled the instrument cluster and took the bulb out for now) or at least until the price of the module goes down if i was you I would pull each wheel off (use a jack stand they save lives) and check the sensors they are about an inch long and an 1/8 inch thick clean off all the metal shavings they collect it because they are magnetic try that see if it helps
1 - 4 of 4 Posts
