1 - 20 of 22 Posts
Discussion Starter · #1 ·
Heyy guys I want to get my gt40s reworked but I would also like to know what other aftermarket heads could I use far as PTV clearance and suggestions would help thanks??!!!
Depends on how much you wanna spend. I just got my gt40s rebuilt with bigger springs, ported, polished, gasket matched, and a 5 angle valve job for about $325. Budget way to go for sure!!
Discussion Starter · #6 ·
Ok so the Trick Flow track heat 170 would b a good choice for a stock 302 with a f303cam and dual roller timing chain or the TF 190... I heard that thre smaller the better to
There are 2 heads that I have found that are most powerful for use on a stock 302. You can use Foxlakeracings TF TW stage 1 ported heads. And the AFR 165ccs. Both supply about the same amount of air on the intake side. The difference is the TF heads have 65% exhuast output which is good for single profile camshafts and the better choice for boost applications (esspecially turbocharging) or all motor applications where drivability is important. The AFR 165 heads have a 80% exhuast output making them better for use with a dual profile cam that has more lift on the exhuast side of the camshaft which is best used for nitrous or maximizing all motor applications. Using one of these 2 heads in your HCI combo will allow you to grow to hit over 500RWHP with power adder without use of a stroker if you desire. Over 340RWHP all motor can be seen from either of these heads used on a 302 with proper cam and intake and a few supporting bolt ons to include exhuast without sacrificing drivability.
NOTE: The horsepower numbers I stated above are real numbers with you keeping your factory engine accesories like alternator, water pump, ac, power steering and even your smog pump. Sceptical? Go to www.foxlakeracing.com and check out their customer rides section.
NOTE: Only differences between Twisted Wedge and Track Heat heads are the TW heads have smog provisons and come with valve springs good up to .520 lift. The TH heads have no smog provisions and come with valve springs good for .600 lift. They are the exact same castings. The F303 cam has .512 lift on both sides which means the valve springs on the cheaper Twisted Wedge heads will work fine.
Note: AFR sells both smog leagle and non smog leagle 165cc heads.
Reminder: When buying a set of aftermarket heads make sure the heads will pass your states emissions tests before purchase if your going to use your car on the street.
Advise: Ronn501 getting the Twisted Wedge 170cc heads and matching Trick Flow Street Heat intake is what I recommend to maximize your power combo using the F303 cam which is a single profile cam. The Fox Lake Stage 1 porting package for the TW heads and SH lower intake is pricey but can give you a realistic 30-35hp to the wheels over what the out of the box versions can do. Also the stage one package from fox lake retains 100% of your drivability. However if a stroker is in your future plans then that will change my advise on heads entirely unless you care about drivability.
I personaly plan to use the TFS TW S1 heads from Fox Lake with a B303 cam or even a smaller custom grind. I am still deciding on intake choice however. I would like to use a Holley Systemax 2 intake if an intake spacer will lower the operational RPM range to retain driveability and maximize top end power. After I figure that out I will probly make my decision. I want my end combo to make 630+RWHP with 9 second E/T's while maintaining most drivability. I am using NMRA Real Street class as a template to base my next mustang off of and fully expect to reach my goals.
Im running The Edelbrock Performer heads with the edelbrock performer intake ported and polished with trickflow stage 1 cam and 1.7 rockers , no issues with PVC and my car dynoed 125rwhp over stock numbers
Discussion Starter · #9 ·
Ok so what I'm goin to do is run AFR 165heads f303cam Trick Flow Street Heat intake and ford racing roller timing chain... I should b ok now probably making around 410 ponys
On a stock 302 shortblock your looking 290-320rwph
---------- Post added at 08:44 PM ---------- Previous post was at 08:43 PM ----------
290-320rwhp*
Does it mater if I have a cobra block
No cobra block and gt blocks are the same, only differences are intake, heads and slightly bigger cam on the cobra, a stock 5.0 dynoes at 185rwhp on average.
TrickFlows topend kit for 360hp that's flywheel horsepower, if your looking for 400hp you'll need a HCI plus supercharger or HCI plus stroker
AFR 165cc heads on a stock 302 are 340+ RWHP capable with proper intake, cam, and exhuast. If 400RWHP is your goal a 302 can potentialy acheive thiese numbers without a stroker or power adder if your on a budget but your going to have to run a very high rpm with a not so street friendly cam.
Ron Robart, Fox Lake's owner, built a 1987 Mustang GT simply to show that with a little thought and some good parts you could build a 306 cubic inch naturally aspirtated, fuel injected motor that would make over 400 flywheel horsepower. This car ran 11.70's @ 119 mph and put over 380 horsepower to the rear tires without the aid of any power adders! Ron's GT features flat top pistons, Canfield Fox Lake ported heads, and an Edelbrock Victor 5.0 intake. This car was featured in the September 2000 issue of 5.0 Mustangs magazine. ~ Fox Lake Website
The canfeild heads are equals to the twisted wedges in my opinion. I would give fox lake a ring and see if they can doo a 400rwhp EFI combo on a stock 302. I bet they can if that article was done 13 years ago. Im sure in order to hit the mark you need a few of the lightest componets you can find for wheels, drilled axles, driveshafts, flywheel and even an electric water pump to maximize your power to the ground.
Also I forgot to mention the type of high RPM you will have to run to reach 400RWHP on a pushrod 302 will require constant adjusting of the rocker arms and the factory crank and pistons are not meant for that type of constant punishment and will be running on barrowed time. Long term the best route to make 400rwhp for your 302 is to use a stroker. If your the type that has the money and want a stroker and power adder a aftermarket block will be needed as the stock 302 block doesnt live very long at 500+rwhp levels. Usually if 500+ horsepower levels are your goal the budget way of acheiving these numbers reliably are engine swaping to a 351w. If 400rwhp is the end of your goals however a stroker and good HCI combo will get you up to 450RWHP.
I do have more to gab about though. I know that power is like a drug eventually you will want more. This also makes the TFS TW heads more desirable than the AFR's because they can always be sent back to Fox Lake for the next level of porting rather than having to buy yet again another set of heads to get to the next level of power. Even still the Stage1 FoxLake heads really outshine the afr's when you add boost on a stroker motor into the equasion. The AFR 165cc heads are great for a 302 but are smallish compaired to the Fox Lake S1 TW175cc heads. From 300-650boosted rwhp the Foxlake Stage 1 Ported TW heads fit the bill and are worth the coin as they can support up to 1400hp with further porting should you ever want to go there.
AFR's are the way to go if your maximizing a naturally aspirated motor or using nitrous due to their higher exhuast outputs compaired to others which means long tube headers really help the AFR heads shine. However if you ever reach for a large stroker like the 342/347 the AFR 185cc's are going to be the bread winner. I have spent years well over a decade playing the mustang building game. After having 6 mustangs Ive done alot of research on what power combos work. Lets face it were not talking Chebys here, Ford engines outperform Cheby motors but require experience on engine combinations to be better. As where with a LS1 you can any brand HCI and exhuast and through it all together and have 500+ RWHP building a Ford is more of a art form and very dominate when done right.
1 - 20 of 22 Posts
