1 - 17 of 17 Posts
Discussion Starter #1
Is it possible to get air in your fuel line? My car is running really rough after it warms up then I go and start diagnosing problems and came to the fuel rail to purg it and there isn't a steady stream of fuel with the key on or off..... Any suggestions?
Look for any kinks or pinches in the lines. Not sure about the air part. Maybe someone has ran into a similar problem though?
---------- Post added at 06:04 PM ---------- Previous post was at 06:02 PM ----------
Fuel filter is also a cheap and easy place to start
Banned
Yup I agree with everything you said. :good:
Discussion Starter #5
I'll drop the tank tmrw and see what I can find. Thanks....would the fuel pump be a possibility?
I would eliminate every possibility I could without dropping the tank. The fuel pump could be a problem, but I've never heard of air in the fuel lines. I would also take a look at the fuel regulator.
---------- Post added at 08:14 PM ---------- Previous post was at 08:13 PM ----------
I'm just a Stang greenhorn though. My forte used to be....Camaros...:(
Banned
Possible, if it is aerating the fuel somehow, like a stuck open check valve, broken impeller, etc..
The only other way for the fuel pump to introduce air is if you run it really low on fuel and the baffles are not sufficient to keep fuel at the pump around corners or up and down steep hills. As long as you have plenty of fuel the pump is submerged.
Discussion Starter #9
Another symptom is that is has a loss of power when driving it and it back fires
Banned
Verify your timing and check the EGR to make sure it's not stuck open.
Discussion Starter #11
Still no luck. All it's doing now is starting and dieing. Ran a scanner on it no codes at all. If it sets for a couple hours it will run for a little and then run rough, back fire, then die and not start again. I'm stumped -_-
Discussion Starter #16
dreamstang said:
i could be wrong. but throwing bones here. ignition parts seem to run worse when they get hot. but both parts i mentioned are testable. if the coil is old i would just replace it anyways. :good:
Coil is only a few months old(msd) tfi not sure of. Gives me a starting point though
1 - 17 of 17 Posts
