1 - 14 of 14 Posts
I would absolutely not do any cai without a tune...it has been proven to cause our cars to go lean which is really dangerous...even cais like the k&n and others that say they don't require the tune just google search it they have been tested
---------- Post added at 12:56 PM ---------- Previous post was at 12:55 PM ----------
If you want to hear the whine of the sc get a smaller pulley you will absolutely hear the whine...that will also require a tune though
If you're changing the diameter of the intake tube then yes you need a tune.. Might as well do it all at once.. Intake tune and pulley.
redbeast0712 said:
Would u need a tune for the roush intake that uses the stock tube? I wouldn't think so but you never know.
Are you referring to the cai for the 5.0 we are talking about the shelby...regardless I would tune any cai that I put on because the cai is not really doing anything for u without a tune
Sorry didn't realize it was only about the shelby just thought i would ask but yes the 2011 to 2013 5.0.
It's cool no problem and to answer your question yeah I would get a tune for the roush it's not doing anything for you without a tune
For sure thanks i have another question ive had tunes on all my cars before on a 2006 gt a 2009 f150 and a couple of v6 mustang but i just got a 2013 gt and im not sure if i want to tune it just because i have had problem with dealers and
Smog tests. Is there anyway that maybe a ford dealer will tune a car if i can get performance parts through them that require tunes
You can order the procal tuner through ford and as long as they install it will not void warranty (supposedly anyway) in regards to the smog test your tune shouldn't affect that unless you were to remove your cats or something the procal will not give you as much performance wise and in my opinion is a waste of money
Thank you for the info. What tuner do you recommend by the way
I have bama, but them Jon Lund, Vmp, they are all good. I chose bama because I was doing my mods slow and liked that they have the "free tunes for life" program...also bama gives a Warrenty to cover engine failures on the # 8 cylinder so it makes since plus bama is a little more conservative than the others so maybe a tad bit safer for daily drive...I plan to eventually get a Vmp tune for my gt500
1 - 14 of 14 Posts
