1 - 8 of 8 Posts
Discussion Starter #1
How hard is it to switch from a auto matic trans to standard, and how do I switch out the clutch pedal and run the cable?
Discussion Starter #5
It turns out that the transmission is too short for the cross member. Can I buy a longer tail to fit or do I need a whole different transmission
Pete Jones
It's really pretty easy(swapping pedals is a pain if you leave the column) I did the swap a few months back.
Discussion Starter #8
I talked to a couple people, they said I'd have to get the crossmember brackets cut and welded up closer to the transmission to fit.
1 - 8 of 8 Posts
